Headlight Bulb Replacement
Old Feb 23, 2006 | 05:48 PM
spatula's Avatar
Default Headlight Bulb Replacement
My right headlight is out and I don't want to take it to the dealer to get a new bulb put in. I figured it can't be that hard of a job to do, but I don't know what type of bulbs I should buy or how to remove the bulbs from the lamp. Any help would be much appreciated. My car is a 2001.5 1.8TM.
Old Feb 23, 2006 | 06:03 PM
jimmysA4T's Avatar
Default RE: Headlight Bulb Replacement
I would just buy them and put it on myself. Is it both bulbs or just one? It's usually easier
to do the one in the driver side but as for the passenger side, you'll probably have to remove
the air filter to do it. Depends on how small or big your hand is I believe the bulbs are
H7 and you can probably get them at some aftermarket shops or try at the local parts store.
If you want the good ones, go to the dealer and buy them and install it for yourself.
Old Feb 23, 2006 | 06:39 PM
CRAZYHAWK's Avatar
H7 is the size.
Old Feb 23, 2006 | 06:45 PM
onepoint8tee's Avatar
You dont need to remove the air filter for passanger side, just the ducting between the front rad. support and the air box, takes litteraly 5 seconds to get off.
Old Feb 23, 2006 | 10:04 PM
sandman's Avatar
yea its easy. just pop your hood and fool around. you should be able to figure it out.
Old Feb 23, 2006 | 10:08 PM
ORIGINAL: sandman
Is that what she said?
Old Feb 23, 2006 | 10:46 PM
miabhai_freaked's Avatar
if u'r confused just look in the owner's manual...in the do it yourself section...
it's explained in detail there...also u can buy the bulbs from u'r local walmart...
just make sure to check the little electronic thing they have there to help
u figure out what kind of a bulb u need...but like these guys said...it's probably
a H7...just be sure to check...dont waste u'r money on the dealer...
lemme know if u need smth
Old Feb 23, 2006 | 11:17 PM
avanttripleloop's Avatar
nobody mentioned not to touch the bulb with your fingers cuz it can blow up when lit from finger oils....phrase of the day..finger oils.use a piece of paper towell when installing.actually miabhai did say more detail in manual.but if you dont have one it's good to know.igot the phillips blue and like them better than sylvania.
Old Feb 23, 2006 | 11:21 PM
socalaudi's Avatar
Just make sure you replace the right one the first time. I started to take the assembly apart before I realized that I was messing with the high beam.
Old Feb 23, 2006 | 11:33 PM
aRIf's Avatar
push and pull it take out the cover
just pull the #1 and #2
