AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   Headlight Issue (already replaced the headlight switch) NEED HELP ASAP (https://www.audiforums.com/forum/audi-a4-8/headlight-issue-already-replaced-headlight-switch-need-help-asap-58685/)
Influentialstylez Mar 27, 2007 02:17 AM
Hello everyone,
I have been around on this site but haven't really made myself known. I own a 1998.5 Audi A4 1.8t. The issue I am having is with my headlights. To start I already tried the diy headlight switch fix, which did not work. I then replaced the switch which still did not remedy my problem. So I have been told it may be a relay causing all of this.I need help asap. If it helps my corner lights still work along with my high beams. Foglights/ low-beamsdo not work along with headlight washers. All interior lights come on indicating a proper working headlight but with no actual result. Thank you for any help and your time.
auditech79 Mar 27, 2007 04:01 AM
RE: Headlight Issue (already replaced the headlight switch) NEED HELP ASAP
Jiggle the ignition switch (key)while trying to operate the headlights, the is a recall for the electrical part of the ignition switch cracking which causes an open circuit to the headlight/wiper system.
Influentialstylez Mar 28, 2007 07:22 AM
Thanks, I tried that as much as I could and it still did not work. Any other ideas anyone?
CRAZYHAWK Mar 28, 2007 10:39 AM
Check the voltage on both sides of the relay. Don't ask me where the relay is.
Influentialstylez Mar 29, 2007 04:03 AM
Can anyone tell me where the relay is? thank you
SacTown_Vlad Mar 29, 2007 04:30 AM
somewhere aroung fuse box... atleast on older cars....
heres picture of it....
http://market.autopartsfair.com/imag...p202019463.jpg
http://www.humanspeakers.com/audi/headlight-simple.htm
