Headlight Issue (already replaced the headlight switch) NEED HELP ASAP
Old Mar 27, 2007 | 02:17 AM
Influentialstylez's Avatar
Default Headlight Issue (already replaced the headlight switch) NEED HELP ASAP
Hello everyone,
I have been around on this site but haven't really made myself known. I own a 1998.5 Audi A4 1.8t. The issue I am having is with my headlights. To start I already tried the diy headlight switch fix, which did not work. I then replaced the switch which still did not remedy my problem. So I have been told it may be a relay causing all of this.I need help asap. If it helps my corner lights still work along with my high beams. Foglights/ low-beamsdo not work along with headlight washers. All interior lights come on indicating a proper working headlight but with no actual result. Thank you for any help and your time.
Old Mar 27, 2007 | 04:01 AM
auditech79's Avatar
Default RE: Headlight Issue (already replaced the headlight switch) NEED HELP ASAP
Jiggle the ignition switch (key)while trying to operate the headlights, the is a recall for the electrical part of the ignition switch cracking which causes an open circuit to the headlight/wiper system.
Old Mar 28, 2007 | 07:22 AM
Thanks, I tried that as much as I could and it still did not work. Any other ideas anyone?
Old Mar 28, 2007 | 10:39 AM
CRAZYHAWK's Avatar
Check the voltage on both sides of the relay. Don't ask me where the relay is.
Old Mar 29, 2007 | 04:03 AM
Can anyone tell me where the relay is? thank you
Old Mar 29, 2007 | 04:30 AM
SacTown_Vlad's Avatar
somewhere aroung fuse box... atleast on older cars....
heres picture of it....
http://www.humanspeakers.com/audi/headlight-simple.htm
andyofne
May 19, 2012 02:40 PM
jag239
Apr 14, 2010 11:21 PM
epeterson
Mar 27, 2010 12:05 AM
MBruns
Jan 29, 2008 10:32 AM
cnelson81
May 30, 2006 03:21 PM
