headlight needs adjustment after lowered?
Old Dec 15, 2006 | 08:20 PM
techbod's Avatar
Default RE: headlight needs adjustment after lowered?
leave it the way it is
Old Dec 15, 2006 | 08:24 PM
techbod's Avatar
ps: VAG will fix this problem the VAS-5051 -VAS6017B are specific dealer tools
Old Dec 15, 2006 | 08:38 PM
kchao2000's Avatar
Thanks guys. Since the headlights and auto-leveling works fine so far without any problems and I don't feel anything wrong with it, I am going to leave the way it is.
If it ain't borken, don't fix it.
Old Dec 15, 2006 | 08:46 PM
techbod's Avatar
Old Dec 16, 2006 | 01:29 PM
dankhound's Avatar
The 5051 is just a scan tool, and the adapater 6017 is just there to comunicate with modules on a different data bus. If you have a later version of vag-com it will comunicate on that bus without an adapter, as the adapter is built into the cable. Check for faults in the headlight adjustment module. There is a tech bullitin for a certain fault that will intermitantly turn on the headlamp warning. The fix is a reflash of the control module. If there are no faults a reflash will also take care of the problem.
Old Dec 16, 2006 | 04:29 PM
kchao2000's Avatar
The dealer told me there is no fault generated from headlights auto-leveling control module. However, they said since the car is lowered, it would be good to adjust the headlights so it could adapt the vehicle.
I think the dealer was just BSing me but not sure.
Old Dec 16, 2006 | 05:50 PM
dankhound's Avatar
Its a good idea to adjust the headlights when the vehicle height is change. They are self adjusting but the baseline needs to be leared so they know where to adjust from.
Old Dec 23, 2006 | 06:25 PM
  #18
Deb38's Avatar
oh jeez that vag seems too complicated for me.my b5 s4 has not been lowered but I feel as though the lights could use some height adjustments, they seem to be aimed too low. The length of my beam is significantly shorter than many other xenon beams. I assume I am going to have to go down the complicated road? No simple screwdriver method for me...? (insert sad face)
Old Dec 25, 2006 | 12:29 AM
  #19
dankhound's Avatar
Its really not that hard if you have a vagcom that is capable of k wire diagnoisis. You just go to 55 headlight verticle control, and go to basic setting 1. Then adjust the headlights where they need to be. Go to basic setting 2 and the position is learned.
Old Dec 25, 2006 | 12:08 PM
  #20
CRAZYHAWK's Avatar
Deb38, you can turn the scews behind the headlights
towards the center of the car. A philips screw driver
works.
