Headlight removal HELP Please
Need some help located the inside bolts to remove the headlights for B5 1999.5..i am feeling around and can't seem to find it ...
RE: Headlight removal HELP Please
You probably need an extender to go in your screw driver. I had to go buy one for a few bucks to get access to that screw driver. Search for the Clear Corner DIY. It should be in there.
--d3 |
Here is a link for a B6 clear corner, but the last screw is in pretty much same location. Hope it helps.
http://www.a4mods.com/index.php?page...earcorner.html --d3 |
A 6" 1/4" drive extention and a T-30bit are needed.
There are two screws on top, and two below, one which is accessed from a hole in the fender, the other behind the light. |
ORIGINAL: CRAZYHAWK A 6" 1/4" drive extention and a T-30bit are needed. There are two screws on top, and two below, one which is accessed from a hole in the fender, the other behind the light. |
Yeah they are not small thats for sure... which sucks a bit because you can't mount them under the light.
Josh |
| All times are GMT -4. The time now is 10:12 AM. |
