Headlight removal HELP Please
Old Dec 25, 2007 | 04:21 PM
kaptom540's Avatar
Default Headlight removal HELP Please
Need some help located the inside bolts to remove the headlights for B5 1999.5..i am feeling around and can't seem to find it ...
Old Dec 25, 2007 | 04:26 PM
d3m0nz3y3's Avatar
Default RE: Headlight removal HELP Please
You probably need an extender to go in your screw driver. I had to go buy one for a few bucks to get access to that screw driver. Search for the Clear Corner DIY. It should be in there.
--d3
Old Dec 25, 2007 | 04:29 PM
d3m0nz3y3's Avatar
Here is a link for a B6 clear corner, but the last screw is in pretty much same location. Hope it helps.
http://www.a4mods.com/index.php?page...earcorner.html
--d3
Old Dec 25, 2007 | 05:04 PM
CRAZYHAWK's Avatar
A 6" 1/4" drive extention and a T-30bit are needed.
There are two screws on top, and two below, one which
is accessed from a hole in the fender, the other behind
the light.
Old Dec 29, 2007 | 10:38 AM
kaptom540's Avatar
ORIGINAL: CRAZYHAWK
the light.
thanks for the information.. 6" 1/4 drive extention worked perfectly. Btw, on the 1999.5 B5 there are only three bolts .. two located on the front and one located on the extreme corner .. HID kit worked out perfectly ..the VVMEballast are huge
Old Dec 29, 2007 | 01:01 PM
Audi_Skydiver's Avatar
Yeah they are not small thats for sure... which sucks a bit because you can't mount them under the light.
Josh
beachchair
May 14, 2008 12:09 PM
bronxblaza117
Jan 15, 2008 02:06 AM
ocadam
Nov 23, 2007 08:06 AM
Gumby11
Aug 15, 2007 04:18 PM
nhltfour
Jun 18, 2006 04:11 PM
