headlight washer jets question?
would anyone know why the headlight washer jets stop working and windshield washer continue to work? This has happened to me and for the last month been in Florida not a freeze issue.
RE: headlight washer jets question?
Maybe a pressure hose popped off and stopped feeding pressure to the pump? Take a look inside the bumper and see if you see anything loose or disconnected around the headlight washer assemblies. Chances are you'll find something.
I'll have to check that out tomorrow. Is that visible once the lower shield is off?
thanks for the fast reply |
ORIGINAL: spectrum would anyone know why the headlight washer jets stop working and windshield washer continue to work? This has happened to me and for the last month been in Florida not a freeze issue. |
washer fluid not low and lights on I made several trys tonight with no luck but a clean window!
ORIGINAL: spectrum I made several trys tonight with no luck but a clean window! Here's another thread that says the headlight washers have a separate pump from the windshield washers. https://www.audiforums.com/m_736634/tm.htm |
are you saying that the headlight washer come on for a few seconds and then go off, if so this is normal, the headlights go on for only a few seconds to get grime off.
ORIGINAL: SAudi are you saying that the headlight washer come on for a few seconds and then go off, if so this is normal, the headlights go on for only a few seconds to get grime off. If the headlight washers diddn't go off after a few seconds, you would have to refill your fluid every time you used your wiper washer things. |
ORIGINAL: spectrum would anyone know why the headlight washer jets stop working and windshield washer continue to work? This has happened to me and for the last month been in Florida not a freeze issue. ORIGINAL: SAudi are you saying that the headlight washer come on for a few seconds and then go off, if so this is normal, the headlights go on for only a few seconds to get grime off. |
ORIGINAL: ucla86 ORIGINAL: spectrum would anyone know why the headlight washer jets stop working and windshield washer continue to work? This has happened to me and for the last month been in Florida not a freeze issue. ORIGINAL: SAudi are you saying that the headlight washer come on for a few seconds and then go off, if so this is normal, the headlights go on for only a few seconds to get grime off. |
