Heat shield
Old Feb 27, 2006 | 01:44 AM
trailboss's Avatar
Default Heat shield
I made this heat shield a while ago, i used some sheet metal and traced out a template on a piece of cardboard. What you guys think, I painted it flat black and i still need to attach it to the evo ms heat shield and put some type of rubber edge on it so it won't rattle.
[IMG]local://upfiles/1765/7B993BDDD98B4A05B4E3D91008F0924A.jpg[/IMG]
[IMG]local://upfiles/1765/A23A7947186348FB8C2405F5F2A0CD73.jpg[/IMG]
Old Feb 27, 2006 | 01:46 AM
trailboss's Avatar
Default RE: Heat shield
I only paited it once so it looks kinda chitty, flat or gloss black if i decide to keep it on?.
Old Feb 27, 2006 | 01:53 AM
Slowb5's Avatar
it seems it would perhaps trap more heat rather than keep it away, imo.
Old Feb 27, 2006 | 01:55 AM
trailboss's Avatar
yea, ive thought about that too, but it also wont let it creep into the intake side as easily, opinions keep em coming.
Old Feb 27, 2006 | 02:17 AM
black991.8tq's Avatar
trailbos i made the exact same thing for my evo intake....i used heat restisant spray stuff, it was black also. well it ended up rubbing on one of the gas lines causing a leak....... after thati left it off. i did test it at the track and did not run a better time.
Old Feb 27, 2006 | 02:22 AM
trailboss's Avatar
did you remove the rear rain tray or whatever it is and the weather strip at the first firewall.
now that i look at ur pics mine is much better, i made the heat sheild go down, to connect to the evo heatshild so it was almost an air box.
Old Feb 27, 2006 | 02:24 AM
i made it fit with the tray and strip in place.
Old Feb 27, 2006 | 02:25 AM
trailboss's Avatar
yea i wanna do that but its not going to be easy since I dont have a k03 anymore or an inlet pipe half the size.
Old Feb 27, 2006 | 02:28 AM
trailboss's Avatar
ORIGINAL: black991.8tq
I took that out a long time ago, reasoning seems logicacooling link should work now
