heater problems...still
Old Jan 20, 2006 | 07:24 PM
pete7's Avatar
Default heater problems...still
ok so i have made several posts about my heater problems. today i was out running errands for awhile and decided to try my heater out to see if it would be warm at all. well i kicked it on high and it was hot as hell! but it only lasted like 2 or 3 minutes and then gradually cooled off and eventually became cold air again. any ideas what could be wrong? could this mean my heater core is partially clogged and needs flushed or what?? any other ideas what could cause this. could a thermostat cause that? cause in my experience, a sticking stat only causes the car to warm up to operating temp really slowly (and use alot of gas) or it sticks closed and the car overheats. could it cause my problem tho??
Old Jan 20, 2006 | 07:25 PM
pete7's Avatar
Default RE: heater problems...still
oh, and by the way, i have a 97 a4 2.8 quattro.
Old Jan 21, 2006 | 01:39 PM
Jestnomen's Avatar
6th Gear
Yeah I would lean toward a clogged heater core myself. Have you checked your climate control for fault codes?
Old Jan 21, 2006 | 01:53 PM
Karl's Avatar
+1 on the heater core.. go ahead and swap that baby out.. if you dont know where it is buried.. go purchase a bentley it should be in there
Old Jan 21, 2006 | 02:04 PM
Jestnomen's Avatar
6th Gear
Well I'd attempt to flush the thing out first with a garden hose.
huntingpastor
Jan 2, 2015 04:29 PM
madmatuk
May 16, 2013 11:10 AM
SloRide
Nov 30, 2009 10:17 AM
islamac
Aug 10, 2008 08:48 AM
pete7
Jan 17, 2006 03:52 PM
