help :(
well my car is not running well...today i was driving it was fine then i stopped at a stop sign took off in first slowly and when i shifted into 2nd and gave it gas it started bogging out...i still have 1k miles till my next oil change its an 03 1.8t
if you know the problem please post a solution thanks
Oksy, from what you have told us, we cant give you a direct answer. there may be somethings you can check that other people here can tell you, but what you relly need to do if you wnt to fix this is to go to somewhere with a vag-com, and have them pull codes from your ECU. they will know what it means. you will get number codes. poast them here on the forums, and someone here will be able to tell you what is wrong with your car.
the shitty part is i just bought the car 2 weeks ago im already taking it back to get it serviced from warrenty...i checked the dipstick too and it was pretty much full a little lower so im still confused my friend said it could be a clogged injector
not to be cheesy but even the cheap OBDII scanner that AutoZone has reads codes- given they are basic engine codes- but around here all AutoZones have them, and they'll scan your car for free, 1st week we had ours my wife called said the engine lite blinked acouple of times- tokk it to AZ borrowed the scanner came back w/ a LRG EVAP LEAK----- (she didn't tighten the gas cap tight!) - hahaha-
I gues what im saying is TDRILL is right if you try to guess you may spend undue money at a shop -$150 or so just for them to say -- nice vacuum leak
ORIGINAL: revolution
so i took my car in for service today they are telling me $690 to fix they said my engine coils are causing my car to bog out
