HELP! APR downpipe does not fit. More.....
Old Oct 17, 2007 | 06:20 PM
BROESPEEDRACER's Avatar
Default HELP! APR downpipe does not fit. More.....
I'm hoping someone can assist me. I have a 1997 A4 1.8t quattro that has been deemed a "GREY CAR" by Maplewood Audi. I found this out recently when I hadrear brake work done on the car by my service tech. The E-brake cables we ordered did not fit.
The problem now is that the APR 3 piece exhaust I ordered does not fit at the downpipe section. The downpipe hits the right transmission bracket.
There has been no mods to the turbo or exhaust manifold. I had a second pipe sent to the shop, but that doesn't fit either.
Any ideas, suggestions? Anyone heard of grey model audis?
I'll look for the original window sticker, but is there any other way to find out the cars original purchase location?
Any problems with APR exhausts?
Old Oct 17, 2007 | 07:29 PM
hiwords's Avatar
Default RE: HELP! APR downpipe does not fit. More.....
wut does grey car mean? and u can prolly find the car's original purchase location from carfax. and y don't u have them custom fit the pipe?
Old Oct 17, 2007 | 07:46 PM
AudiBama's Avatar
ORIGINAL: hiwords
sounds like the best solution, I doubt the problem is at APR's end...so the only way to make it work would be to finagle it into place or have them custom fit it
Old Oct 17, 2007 | 11:55 PM
david9999's Avatar
Make sure that you ordered and were shipped the correct one for the quattro, not front track.
I'm assuming you have a 5 sp not tiptronic as the downpipe wont fit tiptronic.
Old Oct 18, 2007 | 03:49 AM
Leifer's Avatar
With tiptronic transmissions, there's not enough room for the downpipe to fit, so you have to custom fit it; otherwise, you can only do a cat-back exhaust.
Old Oct 18, 2007 | 01:28 PM
The downpipe is from the cat back. The second pipe is the same shape, so it didn't fit any better. The whole exhaust hangs down lower than the OEM exhaust and does not sit up in the tunnel.I have a 5spd quattrowith the sport package.
The choice now is to whether fabricate a different transmission bracket or spend more $ on having the downpipe custom fit.
More suggestions and/or advice is greatly appreciated.
I have pics, butI can't figure out how to insert them into this posting.
Old Oct 18, 2007 | 01:38 PM
hiwords's Avatar
[IMG]site where u uploaded them[/IMG]
Old Oct 18, 2007 | 01:59 PM
A4speed's Avatar
ORIGINAL: BROESPEEDRACER
the downpipe goes on before the cat, not after... (if i understood what you said correctly)
your not suppose to put it from your cat to the exhaust tip
please post pics, i think that would be the best.
Old Oct 18, 2007 | 02:36 PM
This is straight form APR's website:
APR's A4 Exhaust is a stainless steel, 2.5" mandrel bent, cat-back exhaust. On an A4, the catalytic converter is bolted to the turbocharger and then the exhaust begins with the downpipe. Unlike most other aftermarket exhausts, the APR exhaust includes a downpipe. This exhaust is very quiet and simply changes the tone of the exhaust to a deep, unobtrusive sound. With TIG welding, fully stainless construction, and CNC'ed hangers, you will not find a higher quality system on the market.
So I think I have it right.
Are you saying to remove the cat and try to bolt directly to the turbo exhaust?
I moved the pictures from an email to MYPICTURES.
Old Oct 18, 2007 | 04:28 PM
I'm waitng fora response from APR and/or ESC tuning where I bought the exhaust from. Is there anyone else out there that has installed an APR system in a 1997-2001 A4 quattro?
I'm going to use carfax later to try and find the car's origin.
