HELP! before I go to mechanic. Misfire?!?
Old Oct 24, 2007 | 03:24 PM
jonsaudi's Avatar
Default HELP! before I go to mechanic. Misfire?!?
Hello,
Just cruising along this morning all's well until the Check Engine light flashed, then the car started shaking. Several miles later I went to Autozone to get it scanned. The scanner read fault code: P0304 -misfire in cyl #4.
I need to take my car to a Euro mechanic tomorrow and get this worked on. I mentioned to the mechanic that I had my car scanned and all I want is to fix whatever the scanner says needs fixing. He thinks that he needs to scan it again and charge me $165 just to confirm that the problem is a misfire and also so he gaurantee his work. Now, I don't want to spend another $165 on top of what will need to be repaired. So how reliable are these scanners @ Autozone? Should I just have them fix what the scanner says needs fixing, or have them scan it themselves as well? Also, what's usually involved when finding a fault code such as this?
Old Oct 24, 2007 | 03:33 PM
RaudiA4's Avatar
Default RE: HELP! before I go to mechanic. Misfire?!?
Replace your coilpack on cylinder 4. cheap and easy fix, it will take you like 2minutes to replace it
Old Oct 24, 2007 | 04:15 PM
Rob_B's Avatar
$165 just to scan it? That's absurd. Most dealerships will only charge 1 hour of labor to plug it in and diagnose.
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
italia
Aug 12, 2006 10:50 PM
italia
Jun 23, 2005 02:16 AM
