help with code
Old Jan 27, 2007 | 12:30 AM
nyaudia498's Avatar
Default help with code
I keep getting code p0441 which is evap emission control. took it to my mechanic said it was the gas cap being loose. but it came back on and i know i tightened the gas cap enough. what else could it be?
Old Jan 27, 2007 | 02:07 PM
david9999's Avatar
Default RE: help with code
P0441 is the Evaporative purge regulator valve. it sites just behind the air filter box and has several hoses and electrical connections.
Check the hoses coming in and out of the evap valve, especially the little grey and white one way valve on the vacuum line right behind the air filter. This sometimes rubs against some metal clips and wears a hole in itself.
The Evap valve sometimes gets stuck due to charcoal dust, Give it a few gentle taps with a screw driver.
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
snowman_w900
Apr 14, 2010 12:30 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
tonym
Jun 14, 2006 03:49 AM
