Help with codes please
Old Jun 29, 2006 | 07:32 AM
oziaudi's Avatar
Default Help with codes please
Hi Guy's
I bought a Autoscanner U280 VW/ Audi code reader today and read some codes off,
My wifes A4 1995 automatic non turbo,
These codes come out. can anyone please tell me if there bad and how to repair them please.
00532/P1746 Transmission Control module relay-supply voltage B+ Malfuntionlow battery or bad ground. ** FORGET THIS ONE**
00670/ Trottle control switch-E45- Underfined switch position
01119/ Transmission shift range gear position signal **FORGET THIS ONE**
16500/PO116 Engine coolant circuit-range/performance problem
16711/PO327 Knock sensor #1 circuit-low input (bank 1 or signal
16716/PO332 Knock sensor #2 circuit-low input (bank 2
16885/PO501 Vehicle speed sensor-range/performance
17733/P1325 cylinder #1 knock control limit attained
17734/P1326 cylinder #2 knock control limit attained
17735/P1327 cylinder #3 knock control limit attained
17736/P1328 cylinder #4 knock control limit attained
18010/P1602 power supply (B+) terminal 30-low voltage
There was also another one which i could not find 17978 if anyone can help please. **FORGET THIS ONE**
Can Anyone please help me and tell me if these are bad and how I can repair them eg: part numbers, where they can be found on my car.
Any help I would really appreciate heap's.
Thanks in advance
Best wishes
Addam
Old Jun 29, 2006 | 08:05 AM
techbod's Avatar
Default RE: Help with codes please
some codes there mate but checking through them P1746/01119/17978 are bogus codes so forget those as for the rest lets take it in stages and the first issue is a lose/over tight/ poor wiring connection knock sensor which could in theory throw all the other codes so check that first
Old Jun 29, 2006 | 08:13 AM
oziaudi's Avatar
Thank's Avant
your a legend, I will check them tommorrow and I have elminated the codes you said.
Thanks Addam
Old Jun 29, 2006 | 08:17 AM
techbod's Avatar
just found 17978 / P1570 engine control module (ECM) immobiliser active, possible cause incorrect/damaged key, incorrectly coded, ECM/immobiliser replacement without coding, wiring, immobiliser defective.
now if you cant start the car this is your problem
Old Jun 29, 2006 | 08:24 AM
oziaudi's Avatar
She starts first time every time.
Addam
Old Jun 29, 2006 | 08:26 AM
oziaudi's Avatar
Hey Avant
My key is a bit bent would that cause that problem
addam
Old Jun 29, 2006 | 09:22 AM
techbod's Avatar
nop not the key then if it starts that was only one of the possibles so now eliminated, do the first check (clear the codes and see what comes back) if none then it could have been old stored codes where someone didn't clear them.
just to cheer you up I don't think its a big if any problem as long as the CEL isn't on, codes can confuse people when you get so many and the more is better because its generally something simple which causes all the other codes and in many cases its down to the fact the codes were not cleared on a previous occasion
Old Jun 29, 2006 | 09:43 AM
oziaudi's Avatar
Thank's Mate
Also I must commend you on how you are alway's there to help, Don't forget if you ever get to the Gold Coast of Australia let me know. I owe you now 2 beer's Ha Ha
Addam
Old Jun 29, 2006 | 10:05 AM
david9999's Avatar
Well, I'm coming in a bit late.
I'd clear them all, and see what comes back in a week. God knows how long those codes may have been stored, and none are critical.
I have my own vagcom and scan about once a month to catch is new codes are appearing.
Old Jun 29, 2006 | 10:55 AM
oziaudi's Avatar
Thanks David9999, you just want a beer as well don't ya !
Addam
