HELP!!! ESP Light has come on!
Tonight I had the new DICE Ipod interface installed. The ICE Link device is no longer in production as they replaced it with the DICE. The install went smooth and did not seem to hard. The unit sounds great too! After the install was complete and we reconnected the fuse for the head unit I started the Car. The ESP LIght has come on and will not turn off by touching the ESP Button. We repulled the head unit to see if any cables came loose and found nothing. Does anyone have any suggestions. I think tomorrow I will double check the ground wire on the new device, but I do not know if that would cause this issue.
RE: HELP!!! ESP Light has come on!
this has happened to me a few times. When you disconnect the battery and reconnect it the ESP light will come on and stay on. take your car for a spin around the block a few times and it should disappear. (i think it is relearning and checking all the systems related to the ESP).
mannyg_87
02-23-2015 03:08 PM
crazybk187
08-05-2013 04:29 PM
Pbcrazy
09-07-2012 04:25 PM
