Help I broke something
Old Feb 21, 2006 | 12:37 AM
socalaudi's Avatar
Default Help I broke something
I have a 01 2.8l 30v. I broke a hard hose. It starts on the driver side right behind the firewall on a 3 hose connector. Then it runs right across the top of the engine and is held in place by a little holder. After that it goes to the other valve cover, I think to the fuel injection. Im not sure though. Its a hard hose and has a little oil passing through it. Im not sure what it is though. Any ideas? Pics? I would post a pic but I don't have a camera anymore. Thanks.
Old Feb 21, 2006 | 12:51 AM
TroyS's Avatar
Default RE: Help I broke something
Ya might find a engine pic on the internet, then mark it with MS Paint.
Old Feb 21, 2006 | 12:53 AM
onepoint8tee's Avatar
ORIGINAL: TroyS
What is MS paint?
Old Feb 21, 2006 | 01:04 AM
a4BRZLowrider's Avatar
where?
Old Feb 21, 2006 | 01:36 AM
socalaudi's Avatar
Is yours a 12v?
Old Feb 21, 2006 | 01:41 AM
wood_e's Avatar
Does the oil flow at a constant rate? Is there any vacuum on either side of the hose?
Old Feb 21, 2006 | 01:45 AM
socalaudi's Avatar
No it doesnt. The hose is shaped like a U . It starts on drivers side and plugs right into the top of the valve cover on the left. What sits on the head on the passenger side of the car?
Old Feb 21, 2006 | 02:09 AM
wood_e's Avatar
Now I don't own an Audi, but I would guess you broke a PCV line if its connected to the valve cover.
Old Feb 21, 2006 | 02:34 AM
sandman's Avatar
yea the 30 v is different looking. it has a black hose that vents both crank cases. mine broke when i did my valve cover gaskets. they get very brittle over time. its called the crank case breather hose. ECS sells them for $75
Old Feb 21, 2006 | 02:38 AM
socalaudi's Avatar
Thanks man. I just puched in the part number and found it on ecs also right before you posted. Do I need it to run my car because if so then I have to get it fron the stealership tomorrow?
