Help! Limp Mode...
Old Aug 12, 2007 | 02:05 PM
AudiCross's Avatar
Default Help! Limp Mode...
Well my car keeps going into limp mode (5 psi) and every once in a while throws a CEL. It seems to happen when going at high speeds. i cna be on it all i want at lower speds and its fine, but once i spend any significant amount of time over lke 80 ish being on adn off the throttle, it goes into limp. i took it into 2bennett and it hs a running lean code (p0171 i believe) but they ant pinpoint it. we replaced the MAF but still no luck. help please??
Old Aug 12, 2007 | 02:36 PM
techbod's Avatar
Default RE: Help! Limp Mode...
P0171 = system too lean bank 1 possible problems are intake/exhaust leak, AIR system, MAF which you have already done, fuel pressure/pump, injector(s), HO2S (heated o2 sensor),
im for an air leak on the intake
Old Aug 12, 2007 | 02:58 PM
AudiCross's Avatar
thanks. but also forgot to mention that while it was there, they did a intake leak test. Ill be sure to give them that list next time i get it in.
Pb1700cd
Jun 19, 2011 10:10 PM
ericp1.8T
Apr 28, 2010 08:18 AM
jrock
Nov 20, 2007 05:15 PM
Friar99
Aug 3, 2007 05:54 PM
Indiepunk
Jun 22, 2007 08:42 PM
