Help me find this....Jestnomen
Old Apr 16, 2005 | 08:37 PM
konboy22's Avatar
Default Help me find this....Jestnomen
Jest... and every one reading this I know you will say i should search but i have looked all over for it i dont know what keywords to try next. Jestnomen had a maintance page on the A4 for different years as the car grew I am trying to find it so i will see if i got everything done on mine.
I just did all these on mine, drove over 120 miles and yet the 1n 1 code is still on.
Change engine oil
Change engine oil filter
Replace accessory drive belt
Replace timing belt
Replace timing belt tensioner pulley
Replace timing belt idle roller
Replace water pump
Replace coolant thermostat
Change engine coolant
Check electrolyte level of battery
Check brake pad and rotor thickness
Inspect engine for leaks
any other ideas what i should be doing that i have done yet?
Old Apr 16, 2005 | 08:43 PM
Doose's Avatar
Default RE: Help me find this....Jestnomen
Go here. Enter your year/engine and go to the recommended maintenance link.
Audi USA
Old Apr 16, 2005 | 08:56 PM
konboy22's Avatar
found it... it helps a lot. Thanks mate
CRAZYHAWK's Avatar
www.bentleypublishers.com/tech/audi/
Old Apr 17, 2005 | 01:21 AM
CCGIANTS's Avatar
To my knowledge the 1n1 code has to be reset using a VAG
Old Apr 17, 2005 | 01:32 AM
BFlan2001's Avatar
ORIGINAL: CCGIANTS
that's only for the older A4s...i believe pre 98, but it may be 99...if you have a later model you can reset it without vag-com, there's a write-up on aw, it's very simple.
Old Apr 17, 2005 | 02:56 PM
konboy22's Avatar
Its a 98 so were does it fall.... ?
Old Apr 17, 2005 | 03:36 PM
BFlan2001's Avatar
try this....
Krule
Apr 8, 2005 09:51 PM
2.8AudiA4
Mar 3, 2005 11:52 PM
morrisonjd84
Dec 9, 2004 01:17 AM
David_K
Dec 6, 2004 12:56 PM
