HELP ME...i'm desperate
i need to make two radio keys out of something...right now. someone PLEASE give me a suggesion.
RE: HELP ME...i'm desperate
ohh man that title is just so misleading....
did you try the butter knives? maybe take a grinder to them if you have to |
Try 2 hack saw blades (they are nice and thin)
when making your own keys just be careful with the lengh of the key. there is nothing protecting the electronics behind the little hooks that hold in the unit. so if you go too far beyond those hooks you might end up damaging your head unit. kinda like i did :( . but oh well. just a heads up ... good lucky ... i used sissors once or a envelope opener may work ... just go get the hooks out of the way. good luck.
for those of you that have never removed your radios before, you don't actually remove it the way you would think. there are actually two small slits that are on the face of the radio itself that you have to insert the keys into. check it out...see the small slit on the right, in between the 'mode' and 'rds' buttons? there's one on the other side too.
http://i16.ebayimg.com/01/i/04/01/b9/27_1_b.JPG |
try zip ties, it worked for me on my freinds b5, stick them in and pull the radio at the tape/cd slot. dont worry there's nothing immediately back there, youve got like 5 -6 inches of nothing
ORIGINAL: bentframe for those of you that have never removed your radios before, you don't actually remove it the way you would think. there are actually two small slits that are on the face of the radio itself that you have to insert the keys into. check it out...see the small slit on the right, in between the 'mode' and 'rds' buttons? there's one on the other side too. http://i16.ebayimg.com/01/i/04/01/b9/27_1_b.JPG |
im going to say probably not.. because it was like 45 minutes from we he asked for help that he posted those pics
haha whatever man. lookin at the times and stuff... using "logic" to answer questions... you used to be cool!
i think im gonna cry.. [sm=boohoo.gif]
