HELP ME IM DROWNING....
Old Oct 24, 2005 | 05:20 PM
Jestnomen's Avatar
6th Gear
Default RE: HELP ME IM DROWNING....
Have you opened your hood? Any pooled water in there at all?
Old Oct 24, 2005 | 06:45 PM
BLAZEDUPBEE's Avatar
i actually opened my yesterday and like cleaned out any debris around the windshield, and around the sunroof. are there any drains i should know about that can be clogged up? that can spill into the cabin of the car?
Old Oct 25, 2005 | 04:26 PM
i guess ima hafta take the car to the stealership.. [:'(]
Old Oct 25, 2005 | 04:33 PM
RomeA4's Avatar
Dang it sucks man!....good luck though but dang you are going to bank a lot cuz of the stealership.............
Old Oct 25, 2005 | 05:26 PM
yeah man thats why ive been tryna get some help on here. but its kinda hard when its a random **** like this you know.. i just recieved my VAG COM cable so ima see if that can help..
Old Oct 26, 2005 | 11:15 PM
juandango's Avatar
To Quote Jestnomen : Water usually leaks in from three places. The sunroof drain, a plugged AC drain or sometimes water will leak in from the bottom seal around the front window. Have you been running the AC compressor?
Places that can collect water may have a drain , this may be a tube.. The sunroof may have a drain (i am not sure), you where refering to the seal around the sunroof itself.
The A/C has a drain aswell. This may be blocked.
The bottom seal around the front window .was my problem . if you have water built up around the battery .
Have you hosed water over the car and checked inside?
Old Nov 7, 2005 | 07:41 PM
ckandes1's Avatar
has this problem been resolved?
I am having a leak problem right now too, but its definately fromm the rain. I am positive the water is coming in through the firewall. Would a sunroof leak do this? or does this mean it's definately my front windshield?
The water starts above the gas clutch and runs down the left side. it makes a wet spot on the floor under the drivers feet. Then it runs back to the left side backseat and does the same puddling there.
Old Nov 7, 2005 | 07:58 PM
  #18
techbod's Avatar
places to check are A pillars/sun roof drains/scuttle panel under the windshield where the leaves build up there is drains in there too clean them out/pollen filter seal if you have air-con
Old Nov 9, 2005 | 07:31 PM
  #19
ORIGINAL: ckandes1
thats the EXACT same problem ive been having.. from what ive been told there are some drains under the battery that sometimes get clogged and when it rains heavily the water lever rises and some how gets into the cabin. i havent really been able to test the theory but guess what.. its raining now..
http://www.audipages.com/Tech_Articl...tordrains.html if you look towards the bottom of that link it tells you how to unclogg the drains.. Let me know if it works..
Old Nov 9, 2005 | 07:42 PM
  #20
ckandes1's Avatar
ORIGINAL: BLAZEDUPBEE
ORIGINAL: ckandes1
I have a thread called Audi A4 - Water Leak telling about where the leak is coming from, i figrued it out yesterday. Check out the thread. (in a nutshell, its the sunroof suprisingly)
