HELP my locks are ****** up@@@@@@
Old Jun 14, 2006 | 05:07 PM
d_maniac's Avatar
Default HELP my locks are ****** up@@@@@@
right now my locks in my car wont work...not from the remote and not from the inside (only works with key)
i took apart my trunk to take out the motor...I hear it running but the locks are still not working, Is my motor broken even if i can still hear it trying to open the locks??
but the bigger problem from me is the gas door...its locked and i cant open it. My car is about to be on E. Can someone PLEASE tell me where the switch to open the gas door is...
Old Jun 14, 2006 | 05:11 PM
onepoint8tee's Avatar
Default RE: HELP my locks are ****** up@@@@@@
Must be a leak in the system.. Its air controlled. Im pretty sure there is an emergency release for the gas door on the inside of the trunk.
Old Jun 14, 2006 | 05:15 PM
d_maniac's Avatar
i am going crazy trying to find it.........
Old Jun 14, 2006 | 05:17 PM
ORIGINAL: d_maniac
Did you check behind the carpet on the wall that is opposite the gas cap/door? Do you have an owners manual???
Old Jun 14, 2006 | 05:34 PM
david9999's Avatar
There should be an emergency release behind the carpet on the gas cap side. I don't have my bentley with me now.
You can run a vag on the central locking system to check out where the problem might be.
Old Jun 14, 2006 | 05:43 PM
afasta4's Avatar
Yeah my locks are broken also. You can get to the locking pin for the gas tank door just above where your pump is. My pump burned out becuase I had a faulty trunk latch, the pump makes a clicking nois when I try to unlock the car not sure if that helps you figure anything out but maybe. I would suggest doing the job yourself though its easy to replace the pump plus I picked a used one up from the junk yard for $75, much cheaper than the $475 or so the dealer will charge you.
Old Jun 14, 2006 | 05:47 PM
afasta4's Avatar
Tech artical
http://www.audiworld.com/tech/elec131.shtml
Old Jun 14, 2006 | 06:09 PM
d_maniac's Avatar
i used that tech artical to open up the pass side of the trunk....right now the trunk is apart and the motor is out but i STILL cant find that switch to open the gas tank
Old Jun 14, 2006 | 06:10 PM
d_maniac's Avatar
if i hear the motor trying to work that means its still good right??
Old Jun 14, 2006 | 06:25 PM
afasta4's Avatar
Should still be good but don't let it keep running. What they told me about mine was that the pump will keep running for a long time to get the locks to work if you have a problem in the hoses or in my case the trunk latch and it will burn the pump up. What year is your Audi?
