Help with my POS!!!
Old Mar 15, 2006 | 12:46 PM
quattrosedan's Avatar
Default Help with my POS!!!
Hey guys, last week, my car started acting up. Everything is normal when I am daily driving, but when I start to get into boost, it will feel normal for a second but then it like hits a brick wall. It still accelerates, but at a much slower rate. My boost guage still reads the normal boost that I was running before this problem. I thought it was a vacuum leak somewhere, but I used three cans of carb cleaner last night on the engine looking for it, with the car up on a lift. there is not a large/obvious vacuum leak anywhere. So now I am about to put a new fuel filter on it, bc I have run this car out of gas three times now...I know..stupid... and I am thinking that all of the crap in the tank has been pulled into the filter......so I am going to replace that when I get a chance, probably not until this weekend, and hopefully that will be it, though I doubt it. If anyone has any ideas please let me know.
Thanks.
Josh
Old Mar 15, 2006 | 12:55 PM
onepoint8tee's Avatar
Default RE: Help with my POS!!!
No DTC's?? Id start with the fuel filter for sure.. Sounds like its getting the boost but not the fuel.
Old Mar 15, 2006 | 02:25 PM
DTC? What is that? And I agree with you on the boost but no fuel theory.
Old Mar 15, 2006 | 08:43 PM
david9999's Avatar
Find someone with a vagcom to check for stored codes. Could be a vacuum leak or the MAF
Old Mar 15, 2006 | 11:26 PM
ORIGINAL: quattrosedan
Diagnostic trouble code
Old Mar 16, 2006 | 04:08 AM
18T's Avatar
18T
If its the maf go to the dealer its under warrantly up to 80K miles. part of emissions.
Old Mar 16, 2006 | 11:55 AM
Are you sure? My car is a 97 w/ 75k.
And for cels, I had some, but nothing related to this problem. My cel came back on yesterday, so I will do it again and post what it says.
Old Mar 16, 2006 | 12:13 PM
techbod's Avatar
tell the fault code and we can move on
DTC/CEL/EML/MIL all the same thing
ENGINE MALFUNTION INDICATOR
[IMG]local://upfiles/12092/6AF78C3C58824A009DE28EC2C9624839.jpg[/IMG]
Old Mar 16, 2006 | 02:43 PM
I have to get it vagged again to see the new fault code.
Old Mar 17, 2006 | 07:35 PM
Here are a couple of pics of the spark plugs in my car. They are the bosch that came with the elim kit.
