HELP!!!! Need help with minor maintenance
Old Nov 13, 2006 | 01:48 AM
ELECTRO's Avatar
Default RE: HELP!!!! Need help with minor maintenance
My thoughts exactly
Old Nov 13, 2006 | 01:51 AM
acetrebo's Avatar
i think it was meant for arming the car alarm and still being able to leave the windows down or sunroof open. i wouldn't do that personally, but some do.
i have seen some posts where folks adjust the sensitivity so that wind does not set it off as easily.
ORIGINAL: Amze
lmfao... good point
Didnt know theifs could just appear inside, usually it takes breaking in and makes it go off anyway
Old Nov 13, 2006 | 03:41 AM
captcaos2002's Avatar
where is that button located? When I have my windows or sunroof open my alarm goes off and I think it has something to do with the motion sensors.
Old Nov 13, 2006 | 03:49 AM
Amze's Avatar
lol... can something as small as a leaf or fly activiate it?
Old Nov 13, 2006 | 04:05 AM
lol im not sure but it only goes off when my windows are down?? no idea
Old Nov 13, 2006 | 04:20 AM
MissionCtrl's Avatar
17mm socket for the plugs, and a pair of pliers to pull them out with after they are un-screwed
Old Nov 13, 2006 | 08:56 PM
justinxecushyn's Avatar
replaced spark plugs...still trying to locate some coil packs. so far after replacing the plugs...it still is irratic. it stars up but it idles around 1100 when i give it some gas, it'll go to about 2300-2500 then drop down to about 800 and no matter how hard i press the pedal it doesn't respond. is it a waste of time and $$ to still replace the coil packs? there is a cel but i can't check it...can't get to the store. it actaully starts up better and will idle somewhat steady at 1k or 1100...i'm completley stumped
Old Nov 14, 2006 | 07:58 PM
  #18
replaced coil packs...still same senario. what is going on!!!! still trying to locate the maf so i can check there. checked for leaks but i didn't see any at all.
Old Nov 14, 2006 | 09:18 PM
  #19
Lazer Viking's Avatar
sounds like you need an icm
Old Nov 14, 2006 | 10:09 PM
  #20
i found a code...i got "P1545" i dont have a vag com but i did have a obd-ii scanner... throttle body adaptation is so far what i have found but i have no idea what the hell that is.
i'm an idiot. i forgot that i was adjusting my gfb dv and teh keys were in...it was a nice day and i was listening to some music. i saw the battery cables were loose and the neg. cable came off, i put it abck on and tigheted everything back up...this is were everything started.
