Help Please
you mean for the illumination or the hose ?? If it has a light bulb in it there should be two prongs ( +/-) and you tap one (positive) into the wiring for the vent slider illumination or any power source and the other (negative) to a ground. If you are talking about the vac line/hose for the gauge to make it work, read this : http://goapr.com/Audi/support/boost_gauge_pod.pdf
I mean the wire for led lights...they didn't provide any wires like what APR does...
So i want to know should I just go get a black wire and red wire from hardware store and just tie it on the +/- part of the guage??
ORIGINAL: TeeterTawter
i got the apr vdo booste gauge, it didnt come with any wireing harness to light it up, i made a trip to canadian tire [:'(] and tapped into the lights for the vents, its easy.
