Help please 710ndv
Hi, I got chip today and I Did install the 710n dv right before the n75 race valve but I'm not sure if it's the place because the dv pipe is little bigger than oem and is a small pipe on top of the dv I dont know that's for
HELP PLEASE!!!
HELP PLEASE!!!
what????? i think you need to post pix of what you just replaced cuz it has to have a vac line for it to work..... the dv you replaced was under the car right on the pass side????
i wouldnt suggest driving it like that.. maybe nothing will go wrong.. but it only takes about 15 minutes to change the DV .. all you need is a flat head screwdriver.. some clamps.. and some needle nose pliers to pry off the OEM clamps..
