help please with dtc
alright the car is an 05' B6 a4 1.8t quattro. The problem is when i try to set my alarm it does not activate. it locks the doors but i don't get the indicator noise that it is active and the light does not blink. When i put my key in the ignition and shift into drive the trunk indicator says it is open. I check and it is not. I decided to VAG it to see what was up and i got this code.
01013, wsc: 128887
02104: light detection sensor
-g399: short circuit to ground
[sporadic]
does anyone know what this is and where i can find it so i can fix it? I look forward to all help. Thanks in advance.
01013, wsc: 128887
[sporadic]
Yeah, its something wrong with the trunk. That alarm won't arm because it probably thinks the trunk is open. I've never heard of a light sensor in the trunk, but there should be a sunlight sensor in the interior (in a B5, its on the dash). I would check the trunk locking mechanism.
01013 = AC compressor clutch, load signal and fault is wiring or AC system fault,
the other code sounds like a chassis code and could be something to do with solar sensor which is part of the AC system so each code could cause the other and I would put it down to AC fault
