Timing Belt Question
Old Aug 6, 2007 | 12:28 AM
seattle_mariners's Avatar
Default Timing Belt Question
I have a 2001 Audi A4 2.8 Quattro and it currently has 87,000 miles on it with the stock timing belt. In what mileage range is safe until it needs to be replaced in fear that it could break? The wires, spark plugs have been replaced, but nothing else.
[IMG]local://upfiles/38695/F859460B0AE24AF1BDD30D2E60E5CA76.jpg[/IMG]
[IMG]local://upfiles/38695/BA141FD25A23460AB8AACD0E793B74ED.jpg[/IMG]
[IMG]local://upfiles/38695/97740ABC964C4AC5A103BB3AFA02674F.jpg[/IMG]
[IMG]local://upfiles/38695/81D386644F244FF79C0445F5AC2F1282.jpg[/IMG]
[IMG]local://upfiles/38695/49E5423016E347EFB9E38834CEA63DF9.jpg[/IMG]
Old Aug 6, 2007 | 12:38 AM
akielb's Avatar
Default RE: Timing Belt Question
that answer would be get it done ASAP!!!! and thats not kidding
Old Aug 6, 2007 | 12:45 AM
Two things you should know about this vehicle:
A. For the last year, it has not been driven much.
B. It has never been driven hard (previous owner 50+ in age and claims that it was used on the weekends for a smooth ride around town for errands.)
C. Never had mechanical issues.
What are some clues to a failing timing belt? (Not that I'm going to drive it until it breaks but just to be safe)
Old Aug 6, 2007 | 12:53 AM
akielb's Avatar
we have had members with 1.8t's have there's break before 50k - you dealing with a known issue - your MY has the updated tensioners so you can maybe risk a while longer if you want. but if it was me I would get it done soon or do it myself.
no real signs of failure, since the Timing belt itself doesn't usually fail. Its the tensioner that breaks and allows the belt to jump causing the valves to hit the pistons
Old Aug 6, 2007 | 01:10 AM
Is it easy to do yourself if you have such items as a step by step instruction manuelor if you have a medium knowledge of combustion engines?
Old Aug 6, 2007 | 08:52 AM
CRAZYHAWK's Avatar
Check technical articles at,
www.audiworld.com
Old Aug 6, 2007 | 01:06 PM
Bballer0110's Avatar
Woah....Seattle Mariners?! haha remember me from another board??
Old Aug 6, 2007 | 01:31 PM
acetrebo's Avatar
ASAP!!!!!!
Its not the belt, its the tensioner that fails. There is really no signs, it will just break one day, and then you are risking valvetrain damage, and either replacing the engine, or an extremely expensive valvetrain job.
Old Aug 6, 2007 | 08:58 PM
ORIGINAL: Bballer0110
Are you from IGN.com? Or another site?
I heard the "94k service" is when a lot of people get that stuff replaced is what I've read and heard from a couple of private sellers. However, this is very controversial topic.
Old Aug 6, 2007 | 09:26 PM
acetrebo's Avatar
uhh, theres not much controversy about it.
the tensioner breaks and your Fukked. Get it done ASAP.
