HELP PLEASE PEOPLE FUEL PUMP TIPS NEEDED !!!
Old Jul 3, 2005 | 06:16 AM
rnbguy's Avatar
Default HELP PLEASE PEOPLE FUEL PUMP TIPS NEEDED !!!
Hi fellas, my fuel pump isnt delivering fuel, ive tested for voltage on the fuel pump and im getting readings, but dont know which means what, ive listened for fuel pump relay click, it makes the click when ignition switched on, and i cant hear fuel pump whining in the boot, but when the ignition is turned, for a few seconds i hear a whinning noise comming from engine near the center...?
what do i do help needed urgently as i need to drive to work with this car, and i hate taking it to mechanics they tell me to change useless ****
Old Jul 3, 2005 | 06:23 AM
badfeet's Avatar
Default RE: HELP PLEASE PEOPLE FUEL PUMP TIPS NEEDED !!!
i assume you checked all the hoses and filters?
Old Jul 3, 2005 | 06:26 AM
rnbguy's Avatar
with filters ive replaced fuel filter, with hoses i woulda seen any fuel leaks which there arent
Old Jul 3, 2005 | 06:35 AM
lidonnit's Avatar
Change fuel filter immediately.. Here are the step by steps
http://www.audiworld.com/tech/eng.html
It seems that the fuel filter is clogged as hell..... You pump is getting power to it yeah ? & it is making a noise?
Old Jul 3, 2005 | 06:37 AM
lidonnit's Avatar
If you already done fuel filter within the last 20000 miles then your pump is fu.cked
rnbguy's Avatar
i have changed the fuel filter, the adaptor leading into the fuel pump has 4 outputs, they all give off different readings i dont know which belongs to which, and the noise is comming from the engine bay not the boot, is that right?
Old Jul 3, 2005 | 06:46 AM
lidonnit's Avatar
Ok.... this is an interesting one... Sorry about the advice before... I should read thouroughly huh? LOL
I have whinning noise too? its when the ignition is turned on but engine not turned over yeah? Pretty sure thats just a computer or something. I can only think of injectors but the fuel pump should be making a noise at least. take the hose off the fuel pump & see if fuel spurts out... thats what id do.
Old Jul 3, 2005 | 07:16 AM
rnbguy's Avatar
yeah i mite try that, if it does or doesnt squirt what does it mean?
Old Jul 3, 2005 | 07:21 AM
lidonnit's Avatar
fuel pump be like paris hilton on a friday night..... F.UCKED or the wiring is shot to shi.t however you said you heard the relay working and everything so it will be Fuel Pump 95 %
Old Jul 3, 2005 | 07:23 AM
rnbguy's Avatar
yeah your most likely right... i guess i was hoping for something cheaper, hahaha i like ur example
