Help please! Turbo underboost ):
Old Aug 3, 2010 | 12:09 PM
skywize's Avatar
Default Help please! Turbo underboost ):
hi my name is sean and i drive an audi A4 quatro 06'. i recently noticed a loss of power in my car and when i hooked it up to the machine it read code po299. i looked it up and says turbo underboost.
MY SIMPTYOMS: loss of power, bad idoling when parked and also when car is coasting,engine gets hot quick,i hear a weird siziling noise when looking under hood on driver side,i noticed the loss of power around the time i was low on oil ( ): lots of work these days, i noe its terrible)
i did some reaserch and im not sure it could be a map cencer or the d.v(diverter vaulve) but im no mechanic but i would hate to take it to the shop if i didnt have to
CAN ANYONE HELP ME???
Old Aug 30, 2010 | 03:22 PM
bent back's Avatar
had similar problem myself with turbo underboost. also on 06 a4 avant.sorted under warranty, symptom car went into limp home mode. rac gave fault code po299, audi replaced wastegate solenoid. problem remained. audi replaced turbo. problem persisted. by this time both me and audi farly pissed off. but credit to them they persisted and the fault turned out to be leaking inlet manifold.they put a new manifold / gasket. hope this helps. regards,bent back
Old Aug 30, 2010 | 03:34 PM
bent back's Avatar
Default turbo underboost
had similar problem myself.on a4 avant 06. car would go into limp home mode. rac found fault code p0299. turbo underboost. audi replaced wastgate solenoid.fault persisted. replaced turbo. fault persisted,by this time both me / audi pi ssed off.turned out to be leaking inlet manifold. hope this helps regards bent back
Old Jul 11, 2011 | 05:57 PM
swede1973's Avatar
Evening guys, need some help here...
Have had some real issues with my old A6 1.8T 1997 (C5), I have had some massive power loss i my car and when I got overtaken by a "Fiat Panda" yes that's right... I started to worry.
I recently changed my N75 for a brand new one from Germany after the shop I went to in London told me that it was broken. Got a VAG COM cable and software yesterday and did a reading. Now it tells me that I still have a faulty N75??? What could make the N75 brake so easy? I do think my turbo is busted but wont be able to check that until a couple of weeks (on holiday atm).
Let me know what you think.
Thanks,
Hank.
mastoudt87
Nov 5, 2014 11:13 AM
beerghost
Nov 6, 2009 12:22 PM
Dylan19
May 22, 2009 06:57 PM
kerNol
Nov 2, 2008 04:31 PM
b6driver
May 30, 2006 05:11 AM
