Help on reading instrument cluster???
Old Jul 1, 2005 | 11:56 AM
jimmysA4T's Avatar
Default Help on reading instrument cluster???
Hey all, I have a question in particular. As you always see once you start the
A4, you'll see the CD and track on the cd, and the Miles you have left on
your tank display on the instrument cluster. Just yesterday, that disappears
and now it shows 20:15h. I have a Check Engine light on eversince I bought
the A4. Can someone who know or has that issue explain it to me so I won't
be too worried sick??? I have a road trip coming tomorrow July 2nd and I
would like to have an answer as soon as possible. Thanks a bunch guys and
girls []
Old Jul 1, 2005 | 12:05 PM
aznknites's Avatar
Default RE: Help on reading instrument cluster???
i got a 01a4 and i still dunno what that timer is, but i do know that if u click the up down at the end of the signal stalk it does change that to other stats...
Old Jul 1, 2005 | 12:53 PM
InsaneHatter's Avatar
Well in my car (99 A4 QM 1.8T) That is the drive time meter. Shows how long youve been driving. You can cycle through the different options by pressing the end of the wiper switch (may be different on your car). There is
Average Miles Per Gallon
Drive Time
Estimated Miles Left On Tank
Current Miles Per Gallon
Average Miles Per Hour
(not neccassarily in that order)
You can reset the following items:
Drive Time
To reset them you have to hold in the button on the bottom of your wiper switch (may be different on your car, just look around the scrolling buttons for another button this should be the one)
You can also turn off the stats screen by pressing the bottom button (or reset button) once. And once again to turn it back on.
Let Me Know if this helped you!
Old Jul 1, 2005 | 02:35 PM
jimmysA4T's Avatar
Thanks for the fast reply guys. I will try that later and see if it
changes it. Again, thanks!
Old Jul 1, 2005 | 05:25 PM
jimmysA4T's Avatar
Yeah, it's just the drive time so I reset it as InsaneHatter mention. Thanks!
BTW - I found this one article from Audi World's Tech saying that we A4 should never filled gas when
the engine is running and if we do, the Check Engine light will come on and
we have to take it to the dealer to have it tested and reset the light. I can't
remember if I left the engine on while I refilled the gas the day I left the dealer
and it's on ever since then.
I took it to Autozone to have them tested and it came out with the code: Air/Fuel
Mixture. Do I have to take it to the dealer or can I just reset the Engine Light?
Old Jul 1, 2005 | 10:10 PM
GTMA4's Avatar
That happens only sometimes. It is very rare that the check engine light will come on while fueling. Also if it does its normally the air fuel/mix problem. You need to buy a VAG cable to use with a laptop. It allows you to reset the codes as well as do self diagnostics.
simon264
Apr 5, 2011 03:02 AM
asutherland
Jan 22, 2010 09:58 AM
beeasy1028
Aug 6, 2009 07:05 PM
BreezeThe TT
Jun 2, 2009 03:08 PM
audis4v6biturbo
May 3, 2008 05:16 PM
