help removing trim around shifter and ashtray?
Old Aug 24, 2005 | 10:25 PM
psuaudi's Avatar
Default help removing trim around shifter and ashtray?
anyone have any idea how to remove the trim around a shifter and also the ashtray on a 2002 b6 a4?
Old Aug 24, 2005 | 10:57 PM
Dave666's Avatar
Default RE: help removing trim around shifter and ashtray?
Open the ash tray , and pull it up hard , you wont break it.
There are 4 clips holding it down.
Old Aug 24, 2005 | 11:10 PM
psuaudi's Avatar
so that is to remove the trim around the shifter... thank you very much.
what about the ashtray trim cover? is that difficult to remove?
do you know of any tech manual that details how to remove the interior?
thanks again!
Old Aug 24, 2005 | 11:15 PM
Dave666's Avatar
Not sure about any manual..
And I have never removed the ashtray cover.
I wouldnt unless you have to
Old Aug 25, 2005 | 02:06 AM
psuaudi's Avatar
well i might try to replace it because it is scratched up a little
maybe that's something that i could have a dealership do, so that if it gets screwed up, i can blame it on them
do you have any insight on how to take off the B and D pillar trim?
Old Aug 25, 2005 | 02:17 AM
lauren5757's Avatar
I had mine replaced recently because it was all scratched, it lasted about a month before new scratches were all over it, and i don't even know how because I don't put stuff there and things don't touch it, they told me at stupid dealership that it was because i put water bottles in my cup holder and if water drops on it it "scratches" i said BS
so i had them take that one out and put a new one in, the part was under warranty bc i had bought it within the last year or whatever
they put that in, they tell me to take it somewhere and have a clear coat put on it, i leave pissed off
a week later, i look down, and there is a new freakin scratch!!!!!! i hate that stuff
i sort of want to take it off, scrape all the crappy coating off, and put it back on
Old Aug 25, 2005 | 02:50 AM
Dave666's Avatar
ORIGINAL: lauren5757
Which type of trim do you have ?
Old Aug 25, 2005 | 02:54 AM
lauren5757's Avatar
I have a 99.5 a4, my interior is gray, then the trim inside is the brushed metal, but the piece around the shifter is gray as well, just a piece of plastic..... well no, right around it where it shows the gears it is silver as well, then below that it is plastic
Old Aug 25, 2005 | 03:42 AM
aznknites's Avatar
i got a b5 w/ scratches all over it..
how do i pull that off? is it the 4 clips holding that in as well???
Old Aug 25, 2005 | 03:48 AM
Dave666's Avatar
yea should be the same as the B6
