Help with trouble codes before I bring it in
Hi,
I have a 2006 A4 and about 90000 miles. I have this car MD thing that I can hook up to my car to read engine light codes and I have the following codes on it right now. P0171 P0455 P0011 P0441 I want to try to sound like I know a little bit so I don't get taken to the cleaners like I usually do. My engine has been running really rough lately and it seems to be getting worse. I used to get about 400 miles on a tank of gas and I seem to barely be getting 350 lately also. Any help would be greatly appreciated. I may have to make an emergency road trip in the next few days of about 700 miles and want to make sure I don't get in trouble. |
Hey i thought the car Md thing was going to save thousands of $'s.:rolleyes:
The p0171 is the fuel trim out of range. The po455 is evap system large leak. The po441 is another evap code. The p0011 is a camshaft timing over advanced code. I would check the purge control valve , that could be bad causing the evap & fuel trim codes. As far as the p0011 it could be bad cam actuator solenoid , dirty oil feed to cylinder head causing oil starvation. |
Well it does help me in researching what carMD says and what the garage says. Thanks for your help.
