Help with trouble codes before I bring it in
Old Feb 13, 2012 | 12:40 PM
Carole66's Avatar
Default Help with trouble codes before I bring it in
Hi,
I have a 2006 A4 and about 90000 miles. I have this car MD thing that I can hook up to my car to read engine light codes and I have the following codes on it right now.
P0171
P0455
P0011
P0441
I want to try to sound like I know a little bit so I don't get taken to the cleaners like I usually do.
My engine has been running really rough lately and it seems to be getting worse. I used to get about 400 miles on a tank of gas and I seem to barely be getting 350 lately also.
Any help would be greatly appreciated. I may have to make an emergency road trip in the next few days of about 700 miles and want to make sure I don't get in trouble.
Old Feb 13, 2012 | 12:59 PM
M5S5's Avatar
Tech Certified
Hey i thought the car Md thing was going to save thousands of $'s.
The p0171 is the fuel trim out of range.
The po455 is evap system large leak.
The po441 is another evap code.
The p0011 is a camshaft timing over advanced code.
I would check the purge control valve , that could be bad causing the evap & fuel trim codes.
As far as the p0011 it could be bad cam actuator solenoid , dirty oil feed to cylinder head causing oil starvation.
Old Feb 13, 2012 | 01:45 PM
Carole66's Avatar
Well it does help me in researching what carMD says and what the garage says. Thanks for your help.
angelyno55
Aug 10, 2014 09:50 PM
Deekster22
Sep 13, 2009 01:22 PM
pagmann
Jun 21, 2008 01:36 PM
edrocks3
Nov 1, 2007 03:03 PM
acvega
Mar 10, 2005 10:30 PM
