HELP-Whistling noise from wheel
Theres this annoying whistling/sqeeking noise from my from right wheel. I just changed the bearing 2 weeks ago, and got a new suspension... The whistling noise is not constant but its there and .......... me off..
Anyone with any help on waht this could be. THnaks
Could also be brake pads...maybe a stone embedded in the friction material or the pads are thin and need to be replaced. If the pads look good, try putting some anti-squeal goo on the back side of the pads where the piston/caliper push against the pad.
--Larry in PA
--Larry in PA
