Here is a tip to everyone who has a buzzing boost gauge
Old Dec 24, 2006 | 06:23 PM
MC Hammered's Avatar
Default Here is a tip to everyone who has a buzzing boost gauge
This information was supplied to me from a gauge manufacturer which I'll forward on to you. Cheaper than buying new fitting!
Resistor = Restrictor to limit the amount of air that is getting to the gauge
Resistor for a Noisy Gauge
(Make your own Resistor)
Take a short piece of solid core 22 gauge copper wire. Strip insulation away insert the wire into the nylon tubing about two inches from the gauge end of the nylon tube, with the wire inside, heat the tubing with a heat gun until the tubing collapse, remove the heat. When the tubing cools, pull the wire out of the tubing, re-attach the tubing to the gauge. You have just made yourself a resistor.
Old Dec 24, 2006 | 06:52 PM
Deleted User's Avatar
Default [Deleted]
[Deleted by Admins]
Old Dec 24, 2006 | 08:30 PM
18T's Avatar
18T
Default RE: Here is a tip to everyone who has a buzzing boost gauge
isnt the copper end of the T for that? i used my own t and it buzzez like crazy when you shift lol.
Old Dec 24, 2006 | 08:33 PM
BadLuckAudi's Avatar
its usually the VDO's that make the most noise but mine came with a little thing that made the moise go away
Old Dec 24, 2006 | 08:36 PM
18T's Avatar
18T
yeah i got vdo, what was the little thing that came with yourS? and what the **** is this filter thing that came with mine?
Old Dec 24, 2006 | 08:37 PM
yea that filter like thing gets rid of the noise
Old Dec 24, 2006 | 08:41 PM
18T's Avatar
18T
and what does the copper in the T do? doesnt that restrict air as well?
Old Dec 24, 2006 | 08:50 PM
yes i believe so, i didnt have the copper t thing
Old Dec 24, 2006 | 09:26 PM
ORIGINAL: 18T
The copper in the T fitting does exactly the same thing as the tip I posted above.
Old Dec 24, 2006 | 10:09 PM
AudiCross's Avatar
wait, mine buzzes, but only when the guage dropps (i let off the gas) is that what your talking about, or do i just need to lube my guage?
