HID's?????
i purchased halo projectors the ones off ebay, and now i want to buy some hids but i had issues with the harnesses and had to get them rewired so does that mean i cant get hids cause they use the harnesses off the of the headlights and would i have to have them rewired also or wats the deal hope u guys cna help
rewiring as in they cut the wires between the new connector because it was oval shaped and the old one that was circle shaped so the guys cut the heads off and reconnected them usin electrical tape so it was a big mess and a waste of labor fees
this isnt my own pic from my car but thats basically wat my headlight wiring looks like......normal wiring is through a harness with 2 plastic ends that connect well mine isnt so can i have hids or not i dont understand how hard that can be to understand
The HID's plug into the same plug that connects to the back of the actual bulb. not the harness ouside the housing. you'll drill a 22mm hole on the back of the housing to fit the bulb through. Just order a kit and you'll figure it out, its not that hard
well last thing... i sawa how to install thingthat u need to drill a 1" inch hole into the backof the housing and that makes the plastic tube go into the bulb holder is that nessecary or do u take the plastic tube cause thats just a protector for the bulb in the box..... and i cant just order them cause my parents wont let me so i gotta find a shop around my area that will order them for me or i would of bought them a long time ago
