AudiForums.com
-   Audi A4 (https://www.audiforums.com/forum/audi-a4-8/)
-   -   High flow cat (https://www.audiforums.com/forum/audi-a4-8/high-flow-cat-15580/)
turbo Aug 31, 2005 02:13 AM
High flow cat
Are they junk or are they ok?
turbo Aug 31, 2005 02:21 AM
RE: High flow cat
If I stick with stock exhaust and use a high flow cat will I have gains?
I orderd a borla cat back but it has a 3 weak back order. so I am looking for somthing for now.
PandaXpress Aug 31, 2005 02:24 AM
RE: High flow cat
why dont u just get a test pipe
you'll get some crazy gains but i dont think u will ever pass a smog check again
BzeA4 Aug 31, 2005 02:41 AM
RE: High flow cat
I've been wanting to get a test pipe but have to pass emissions.
But was wondering if a Test Pipe is interchangeable with the cat? and how long of a process is it?
trailboss Aug 31, 2005 03:08 AM
RE: High flow cat
Yep, you will fail emissions with a testpipe. A testpipe is a direct replacement of your CAT, it isn't that hard of a task to do, the hardest part is getting the bolts loose where it connects to the downpipe. The 3 bolts on the turbo are cake. Use lots of PB blast for the DP bolts and it should be fine. If any of the bolts wont come off the DP CAT connection dont cut the top bolt off, bad idea, the nut on the backside is welded to the cat, i spent 2 hours with vise grips turning it out. After you install it and all the bolts are fresh and free of rust, its east to remove. I just removed mine the other day along with the turbo, it took me an hour get the car on stands and remove the CAT. First time should take you 3 hours at most if everything goes ok.
BzeA4 Aug 31, 2005 03:21 AM
RE: High flow cat
Ok, thats good to know. So once i get it done the first time, if i ever need to put the cat back on i will be able to, right?
trailboss Aug 31, 2005 03:29 AM
RE: High flow cat
Yep, just take the tespipe out and through in the CAT for emissions and then once your done put the testpipe back on. Only thing you might want extra of are gaskets, just to make sure there is a tight seal.
BzeA4 Aug 31, 2005 03:30 AM
RE: High flow cat
Allright, thanks for the heads up on the gaskets.
