High Flow Cat???
Old Nov 25, 2007 | 08:40 PM
LaplaceTransformOfS's Avatar
Default High Flow Cat???
Hello. I am sort of a n00b here at AudiForums. I was wondering what kind of difference a HFC will make...I am not expecting the boasts of 20HP + 40Ft*Lbs of torque, but I just wanted to know if the claims were true that a) they give about 8-12HP andaround 30ft*lbs of torque and b) they have better fuel economy over the stock cat. If I'm really not going to notice the difference, I really don't see the point...Any input is greatly appreciated!
Old Nov 25, 2007 | 08:43 PM
cincyTT's Avatar
I'm make believe
Default RE: High Flow Cat???
The stock cat isnt a restriction. You should either leave it or get a testpipe.
Old Nov 25, 2007 | 08:44 PM
A4speed's Avatar
I have a 2.5" dp and high-flow cat from techtonics, you can feel a slight difference after the install. I would say around 10, maybe 15 hp if you get both the dp and cat.
Old Nov 25, 2007 | 08:57 PM
aRIf's Avatar
it's as same price as chip even more expensive. get a chip.
Old Nov 25, 2007 | 08:58 PM
Quattro_1.8t's Avatar
ORIGINAL: aRIf
+1 chip and test pipe is the way to go.
Old Nov 25, 2007 | 09:01 PM
98 a4's Avatar
I will agree with cincytt and just get a TP becasue they are alot less expensive give you good performance for the money.
Old Nov 25, 2007 | 09:04 PM
cantdrive55's Avatar
The problem with going TP is some of us still have to pass emissions. I've looked at the LaBree HFC and its under $300. Magnaflow also has one for about $220.
Old Nov 25, 2007 | 09:19 PM
cincyTT's Avatar
I'm make believe
The cat is attached to the turbo and flanged on the other side aswell. A universal cat wont work
Old Nov 25, 2007 | 09:29 PM
Labree will make a custom one to fit and Magnaflow has a cat designed for the Audi 1.8T.
Old Nov 26, 2007 | 11:21 AM
rccks96's Avatar
ORIGINAL: cincyTT
Really? I've heard that the cat is the biggest restrictor in the exhaust system (for the B6 at least).
Is it different for B6 vs. B5?
