HIGH VACCUM READING AT IDLE??????????
Old Mar 21, 2007 | 11:15 AM
Makaroni1313's Avatar
Default HIGH VACCUM READING AT IDLE??????????
I have a stock B5 that I want to mod. I am starting by fixing the problem areas on the A4 (i.e timing belt, clutch, DV, K03......) you know the regulars. I noticed something that seemed odd for a turbo car, the vac reading at idle, after warming up, is 22 in/hg. Is this normal for the A4 or should I be looking for a contributing part failure? I have another B5 that is Under construction and I never took a vac/boost reading before I ripped it apart. Any info would be greatly appreciated.
Old Mar 21, 2007 | 12:22 PM
akielb's Avatar
Default RE: HIGH VACCUM READING AT IDLE??????????
Thats normal - nothing wrong
Old Mar 21, 2007 | 12:46 PM
kpatz's Avatar
When the throttle is closed (foot off the fast pedal) you are going to get the highest vacuum level. This is normal.
Old Mar 21, 2007 | 05:39 PM
Audi_Skydiver's Avatar
Mine is low!!! I am at 11 when I am idleing
Josh
Old Mar 21, 2007 | 05:41 PM
onepoint8tee's Avatar
ORIGINAL: ThePaintballGuy
Josh
You have a vacuum leak or clogged air filter.
It's a leak. I just replaced my filter last night.
Josh
Old Mar 21, 2007 | 07:24 PM
limptimtim's Avatar
Josh
me too stupid leaks
Old Mar 21, 2007 | 07:30 PM
How are you going to try and find them? What problems can that cause???
Josh
Old Mar 21, 2007 | 07:59 PM
Alan777's Avatar
Mine settles at 25 when I idle. I thought it was super low, but the car runs great.
Old Mar 21, 2007 | 08:05 PM
tooxtreme8813's Avatar
you car will run liek crap and you will either un rich or lean and screw things up even more
