hissing noise when starting
Old Nov 20, 2007 | 01:28 AM
mdorsal22's Avatar
Default hissing noise when starting
good evening, i have a 98 quattro A4 2.8 with 105k..
lately there has been annoying hissing sound upon startup and sometimes frequent with the engine running for awhile.. just checking if this is a simple serpentine belt replacement needed or anything further(pump or compressor).
any help is greatly appreciated!!!!!!! thks -md
Old Nov 20, 2007 | 01:39 AM
A4speed's Avatar
Default RE: hissing noise when starting
does it do it when you drive to, or has it at all?
if it is:
its the connection right above the red hose.
Old Nov 20, 2007 | 01:57 AM
hiwords's Avatar
does it sound like air escaping or a super loud frog?
Old Nov 20, 2007 | 02:15 AM
mdorsal22's Avatar
hi thanks for the response guys.
ok it is more like a loud hissing/whining noise but only lasts a minute or two.. im thinking its related to the a/c or thermostat ??
Old Nov 20, 2007 | 03:15 AM
A4speed's Avatar
ok, so when you push the gas it has never hissed?
if not, then what i said is not the issue
Old Nov 20, 2007 | 08:42 AM
turbo kraut's Avatar
Tech Guru
ORIGINAL: A4speed
also he has a 2.8, that pic is of a 1.8t motor
Old Nov 20, 2007 | 09:22 AM
sineo's Avatar
It only lasts a minute or two? Sounds like the Secondary Air Pump. Do the rpms drop by a few hundred when the noise stops (easier to notice while in park)? If that sounds right, scan for codes, you might find P0411. Hell, scan for codes anyway. Autozone and Advanced will do it for free.
Old Nov 20, 2007 | 10:31 AM
phillyfan1290's Avatar
yeah my car makes that noise aswell onlky when it first starts its really annoying lol i checked sounds like it might be comming from the belts not sure thow prob taking it to machanics soon
Old Nov 20, 2007 | 10:35 AM
rbrtech's Avatar
Air pump is more than likely your problem check the connections from the pump. You may get lucky but the pump does like to crack and break rivets
Old Nov 20, 2007 | 10:40 PM
mdorsal22's Avatar
great thanks!! im gonna look it up in the repairmanual.. i just got a new serpentine belt todayand replacing it on friday.. i willpost a reply after installing and let you know if it has soved the noise...
03allroad
Jan 2, 2009 09:10 PM
audidude89
Dec 26, 2008 10:28 AM
Jc61990
Dec 6, 2008 01:25 AM
quattrolove
Dec 5, 2007 02:29 PM
DAMIANWOZ
Feb 26, 2006 10:05 PM
