HKS SSQ on 1.8t's??
Old Sep 22, 2007 | 02:02 AM
kemp_travis's Avatar
Default RE: HKS SSQ on 1.8t's??
ok...so im going to go with the 004 from forgemotorsport.com i cant find it on ECS
but how does it sound, is it very distinctive? does it run fine with tht line being plugged?
and how do you adjust it for the pressure release?
Old Sep 22, 2007 | 02:07 AM
cincyTT's Avatar
I'm make believe
ORIGINAL: kemp_travis
ok...so im going to go with the 004 from forgemotorsport.com i cant find it on ECS If you can find it on forges site, you should be able to notice the 4 differnt colors they have listed on ECS's site. If they dont have it listed for your A4, you can just go under the TT, Gti, Jetta or w/e and get it. They are all the same.
but how does it sound, is it very distinctive? Here is mine, this was before i fully tuned it so pay no attention to the stupid comments
does it run fine with tht line being plugged? That makes no sense
and how do you adjust it for the pressure release? Its the same as the 007 and uses that same springs
Old Sep 22, 2007 | 02:15 AM
im running 14psi....will i need to buy the spring set?
Old Sep 22, 2007 | 02:30 AM
cincyTT's Avatar
I'm make believe
It would be a wise investment
Old Sep 22, 2007 | 02:37 AM
ya...its only $15
and once i get my chip ill be running more psi...so it'd be nice to have the other higher srings layin around.
but it doesnt vent at idle like the stock ones do?
and do i just pop the b!tch in where i take the old one out?
Old Sep 22, 2007 | 01:37 PM
cincyTT's Avatar
I'm make believe
but it doesnt vent at idle like the stock ones do? Correct, closed in vacuum unless there is boost in the charge pipe.
and do i just pop the b!tch in where i take the old one out? Pretty much
