hmmph...
Old Mar 19, 2006 | 09:16 PM
Slowb5's Avatar
Default hmmph...
Hey guys...coolant temp gauge on the hud isnt working...anyone know of how to check if the sender unit is working and where its located?? thanks.
Old Mar 20, 2006 | 02:19 PM
Slowb5's Avatar
Default RE: hmmph...
bump....anyone?
Old Mar 20, 2006 | 02:20 PM
GraffixWB's Avatar
get a new sensor. they are 15 for the blue and 5 for the green. most likey the culprit
Old Mar 20, 2006 | 03:00 PM
Slowb5's Avatar
where are they located?
Old Mar 20, 2006 | 04:52 PM
aaronamericahall's Avatar
when my temp. guage stop working I was going to replace it but when I looked at the sensor which is in the back of the motor right in front of the battery bay, I found a lose wire from the temp sensor connector that came disconected some kind of way so I put the wire back together it worked fine.
Old Mar 20, 2006 | 05:07 PM
aRIf's Avatar
it is very close to firewall. look at the between engine and firewall you'll see the sensor. it is like end of a pipe. and connect a cable top of it. you'll see the color easly either blue or green.
Old Mar 20, 2006 | 11:18 PM
Slowb5's Avatar
rad guys..thanks a bunch...too late to go check it now but imma see it 2morrow.
