How to determine cat converter size?
Old Mar 23, 2006 | 11:51 PM
707782y's Avatar
Default How to determine cat converter size?
Where can I find the engine code so I can get the correct cat converter size?
Or how can I get te cat converter size for my car, esctunning has it as 2.25", 2.5", and 3.0", which one should I buy for my car?
Old Mar 24, 2006 | 06:21 PM
hoonee46's Avatar
Default RE: How to determine cat converter size?
If you haven't tried searching, do so please.
oh, and there are lots of knowledgeable people in here, but I don't think they can memorize or foresee what car all members have, so please, post a year/model... 1.8t? 2.8? y'know, at least the basics.... so everyone has somewhere to start from...
Old Mar 25, 2006 | 01:39 PM
david9999's Avatar
None of those are direct fit for OEM exhaust systems.
what make you think you need a new converter?
Old Mar 25, 2006 | 01:44 PM
techbod's Avatar
2.25", 2.5", and 3.0" pipe diameter size not catalist size ya gotta laugh aint you
Old Mar 26, 2006 | 03:05 AM
707782y's Avatar
People, bear with me, two months ago, I don't know shiz about car, but two months later, I learned a lot about car, but I still have a ton to learn, so bear with me, and help if you can. Thanks
so, 2.25", 2.5", and 3.0" pipe diameter size, how do you determine what pipe diamether size I need, or can I just use any, will it make any difference?
Old Mar 26, 2006 | 03:06 AM
707782y's Avatar
ORIGINAL: david9999
Because I got this engine code: P0421
Old Mar 26, 2006 | 06:36 AM
BadLuckAudi's Avatar
What car are we talking about here, if we knew that we might be able to give you a more direct answer
Old Mar 26, 2006 | 06:57 AM
techbod's Avatar
that's a simple one p0421 is bank 1 catalyst ( that's the side where number one plug is on if its a V6 ) you cant make a mistake changing it because you can only buy the one for that side they are both different and include the front pipe as a single unit
Old Mar 27, 2006 | 03:23 AM
707782y's Avatar
ORIGINAL: avant80@2.6
I really appreciate all your reply, but I must admit that all your reply is useless to me some way or another.
So, are you saying bank one means the side on the driver's seat or the passenger?
Old Mar 27, 2006 | 10:59 PM
707782y's Avatar
I really need your guys help.
which size---2.25", 2.5", or 3.0" pipe diameter size is the correct pipe size for my car in the sig.
