How do i make the Blow Off Valve sound
Old Sep 30, 2007 | 01:20 PM
Slow4Show's Avatar
Default How do i make the Blow Off Valve sound
Just got a 2006 2.0t and i want to make the BLOW OFF VALVE LOUDER whats the cheap way and the expenseve way
can i do a manual boot controler?
Old Sep 30, 2007 | 01:21 PM
FASTER's Avatar
Tech Slut
Default RE: How do i make the Blow Off Valve sound
cold air intake
Old Sep 30, 2007 | 01:32 PM
Audi_Skydiver's Avatar
And its a DV, Diverter Valve, not a BOV.
Josh
Old Sep 30, 2007 | 01:36 PM
CAB509's Avatar
6th Gear
ORIGINAL: Slow4Show
Sell the Audi and by a Honda.
first of all Audi's run Diverter Valves, not BOV's and while it is possible to put a BOV on an Audi it is not the easiest thing to do. Second, doing any mod "for the Sound" pisses most of the mebers here off and you should prepare your self for some flaming. third if you want to here the DV a little better, yes an intake will help "the sound".
I thnk I heard somewhere that you can't actually put a BOV on a 2.0T yet, but CincyTT would be teh guy to ask because he is the big BOV guy on here.
Old Sep 30, 2007 | 01:37 PM
CLX's Avatar
CLX
Zombie Defense Force
Use this
Old Sep 30, 2007 | 01:39 PM
The Bishop's Avatar
Just disconnect the recirc tube. That could never give you any sort of problems, none at all, I promise.
Old Sep 30, 2007 | 01:47 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: CAB509
You can add one to any audi/vw. For the 2.0T all you need is a forge spacer. Head over to 20squared.com, they have everything you need.
I would think by now you guys would start giving accurate info instead of ignorant bashing.... guess i thought to highly of some people
Old Sep 30, 2007 | 02:01 PM
jinnyboo's Avatar
is it the same for the 1.8t?
Old Sep 30, 2007 | 02:08 PM
A4speed's Avatar
ORIGINAL: FasterA4ThanUrs
cold air intake
when i got my carbonio intake, you can hear it going through the dv a lot better then the stock box, it sounds like a quietter bov basically.
Old Sep 30, 2007 | 02:11 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: jinnyboo
forge 004 is all you need. you can get one from ecstuning
