How do I remove the ABS sensor and.....
Old Nov 22, 2005 | 07:55 PM
bhj0887's Avatar
Default How do I remove the ABS sensor and.....
How do I remove the rear ABS sensor and the joint holding the upright in.
I don't see any bolts for the sensor and it won't pop out.
This is the passenger side rear wheel, the joint I'm talking about technically is next to the sway bar mounting point on the upright. Its on a balljoint looking thing.
Any ideas?
Old Nov 22, 2005 | 09:29 PM
AudiTech04's Avatar
Default RE: How do I remove the ABS sensor and.....
You should go ahead and buy a new sensor because you are going to break that one
I should have one bolt in it but if not it will just pull out
Try using some penetrating lube and pliers
Old Nov 23, 2005 | 11:52 AM
insuite's Avatar
on my '00 the abs sensors just pull out, no bolts.
Old Nov 23, 2005 | 12:02 PM
bhj0887's Avatar
I'll try that.
I guess I'll try a tie rod end puller or something or that joint.
Old Nov 23, 2005 | 12:42 PM
techbod's Avatar
http://images.google.co.uk/imgres?im...l%3Den%26lr%3D
Old Nov 23, 2005 | 07:09 PM
insuite's Avatar
squirt the s%!t outa of it with wd-40 or similar.
Old Nov 25, 2005 | 06:15 AM
bhj0887's Avatar
I got it all apart.
The sensor pissed me off and really wouldnt come out, so I ripped it out. I lost all of my patience so a new ABS sensor is defenitly in order now.
You can see pieces of it circled. Pieces of the CV and bearing. The partially non existent bearing and gouged rotor.
<img src="http://i2.photobucket.com/albums/y3/bhj0887/AUDI.jpg>
Old Nov 25, 2005 | 06:19 AM
bhj0887's Avatar
I forgot how to post picture on here...so
here ya go.
Old Nov 25, 2005 | 07:27 AM
BFlan2001's Avatar
let me know if you find one for a good price, i may have to replace one of my abs sensors
Old Nov 25, 2005 | 11:04 AM
bhj0887's Avatar
Will do, i'll let ya know howm uch I pay for it when I get it.
