how in the h*$#!!!
Old Apr 2, 2007 | 05:48 PM
B5luver's Avatar
Default how in the h*$#!!!
How in the world are you supposed to get those damn clips off, that hold the vaccum lines onto the N75 valve... please help me
Old Apr 2, 2007 | 06:04 PM
x1rider's Avatar
Default RE: how in the h*$#!!!
Yeah, if it's the ones I'm thinking of (the crimped OEM hose clamps), tin snips or dremel with cut-off wheel work well.
Old Apr 2, 2007 | 07:09 PM
Jeff's Avatar
Zombie Defense Force
i use tin snips or just try to break them with a flat head screw driver
Old Apr 2, 2007 | 07:12 PM
akielb's Avatar
snip snip snip (thats three snips for the three N75 lines) you'll be hard pressed to find a clamp that will go down that far so you'll be forced to either get a tool that allows you to make the crip style OEM ones or do what most people do and use zip-ties
Old Apr 2, 2007 | 07:32 PM
BadLuckAudi's Avatar
lol ya you just gotta bust them lil basturds off
Old Apr 2, 2007 | 07:37 PM
B5luver's Avatar
Yea those bastards put up a fight!!! I finally got them after lots of cutting and then I finally realized that all you need to do is loosen them up a bit (and I mean barely) and just break the seal between the hose and the valve and just pull the valve right off. N75 race valve now in. Thanks guys, now I'm just trying to figure out the headlight warning thing and plopping resisters in cuz of my HIDs
Old Apr 2, 2007 | 07:42 PM
clconversion's Avatar
side cutters and just twist they will break pretty easily
Old Apr 2, 2007 | 07:45 PM
cincyTT's Avatar
I'm make believe
I just used a flathead and slid the whole lineback a bit and the lineslid right off with a little pull. And when the vac lineis off, you can just pull them off the vac line.
Old Apr 2, 2007 | 08:20 PM
scotts custom's Avatar
how is th n75h?
Old Apr 2, 2007 | 09:11 PM
B5luver's Avatar
well in all honesty, doesn't seem different at all, maybe a bit smoother, but we'll see when the chip goes in soon...
