How to improve gas milage?
Old Dec 30, 2004 | 07:27 PM
a224932's Avatar
Default How to improve gas milage?
Ok, so I have had my 1999.5 A4 1.8T (manual) for about 5 months or so. I regularly drive from SLC, UT to Las Vegas NV (which is about 420 miles). I don't have a trip computer but have figured I get about 24.5 mpg on that trip (I get about 360 miles on a 15 1/2 gallon tank before I am on empty). I am averaging about 85 miles and am using the cruise control with no AC. I would not be concerned but according to the manual and such I should be getting almost 30 on the highway.
Any thoughts on what I can do to improve the gas milage? I changed my air filter about one week ago as well as the oil (Mobil One 0w5w) and just today I changed my plugs (it was a lot easlier than I thought) without getting a CEL. I am going to Vegas tomorrow and just wanted to see what else I can do to improve the gas milage.
Old Dec 30, 2004 | 07:28 PM
Jestnomen's Avatar
6th Gear
Default RE: How to improve gas milage?
May want to try some fuel injector cleaner, I would recommend Gumout Regane. Also changing your O2 sensors will inprove fuel economy.
Old Dec 30, 2004 | 08:06 PM
audiboy1618's Avatar
get a festiva
Old Dec 30, 2004 | 09:12 PM
CRAZYHAWK's Avatar
Slow down. Check tire pressures with tires cold. Don't carry heavy things you don't need. Never use a roof rack.
Old Dec 30, 2004 | 09:13 PM
CRAZYHAWK's Avatar
Jest , I tried Gumout Regane and mileage memained the same.
Old Dec 30, 2004 | 09:34 PM
Jestnomen's Avatar
6th Gear
I used the stuff like for a month solid. It probably won't work if your injectors are clean to begin with (or not nearly as dirty as mine).
Old Dec 30, 2004 | 10:03 PM
black991.8tq's Avatar
i heard that if your diverter valve is bad your milage will go down
Old Dec 31, 2004 | 04:59 AM
a224932's Avatar
Thanks for all your input, I will be putting in some fuel cleaner both ways and see how it goes. I need to replace my DV, and just want to know if it is something that I can do. (I feel totally comfortable changing my oil and spark plugs and air filter) If I can do this, do you think changing my DV would be in my skillset?
Old Dec 31, 2004 | 03:23 PM
Transverse's Avatar
DV swap is VERY easy. Do a search of the archives, there are some pretty good instructions on how to do it posted at this forum. You can always drop me a PM if you can't find it or if you're still confused.
-T
Old Jan 1, 2005 | 02:35 AM
david9999's Avatar
Are you using 91 octane gas?
Borrow a VAG and check for codes.
Drive at 75 mph rather than 85 mph
Increase the inflation on your tires from the recommended 32 psi to about 40.
