how many turbos
Old Jan 14, 2008 | 11:49 AM
marlonduval's Avatar
Member
Default how many turbos
i posted this in the turbo sections but none answer im planing on buys the ko4 turbo but would i be able to buy 2 and install both in my b5 1.8tq engine or can i also keep my ko3 and instal the ko4 with it..basically i wanna make a twin turbo
Old Jan 14, 2008 | 11:55 AM
CAB509's Avatar
6th Gear
Default RE: how many turbos
so let me get this straight you want to TT a 4 cylinder car, I mean I guess it could be done. I would def get two KO4's or 2 K03's, I would not mix and match turbo's unless I was doing a sequential setup.
Thats my .02 cents
Old Jan 14, 2008 | 11:57 AM
01afour's Avatar
yeah that sounds like a lot of custom fab. work too. do you know someone that really good with making custom piping cause your gunna need a lot. it would be cool to see though.
FASTER's Avatar
Tech Slut
ive never heard of a biturbo on such a small displacement single bank block... im not sure it would even work unless you are bill gates... you should just go BT and forget about this sillyness
Old Jan 14, 2008 | 12:07 PM
viper9821's Avatar
Sounds like a really stupid waste of money, more stupid than a turbo 2.8. Spooling 2 turbos with a 1.8 wouldn't be fun and theres probably no room to fit 2 with piping and all supporting stuff. I can't imagine how much it would cost.
Old Jan 14, 2008 | 12:17 PM
cincyTT's Avatar
I'm make believe
no, its not a good idea. Only 2 pulses dont give enough flow for the turbos. Just scrap the idea because it will cost more than a simple BT upgrade
Old Jan 14, 2008 | 05:16 PM
msrp:priceless's Avatar
Um...do you LIKE migraines? You're gonna have a few if you attempt this craziness. I did a single turbo KIT install on my mustang-yea it sucked. I couldn't imagine trying it on my 1.8 Audi.It would be pointless, other than trying to set yourself apart from the crowd(which I can respect). But, seriously...you would have to run a stand alone ignition system and all that to support a wild set up like that wouldn't ya??I know Bugatti runs quad turbos, but that's also on a w12 or w16 with engineering freaks of nature building it.If you get that done and your car actually runs...PLEASE post those pictures and your process of install...if you can fit all that in this forum
Good luck if you go for it!
Old Jan 14, 2008 | 05:30 PM
chaos92287's Avatar
nah, what r u people talking about? you just run 1 turbo into the other. that way your double turbocharging the air!!! waaay more power than those stupid BT's everyone else is investing their time and money into
Old Jan 14, 2008 | 05:56 PM
qUaTtRoA4's Avatar
I think your best bet will be a single big fukn turbo....like a Gt30 or langer...which'll be about the same size as 2 KO3's...
or you coulg go Ko4 pc-16 and then run a shot of nitrous...that should be pretty interesting!
gl!
I-4 bi-turbo is not a very good idea...
Old Jan 14, 2008 | 06:01 PM
SouRce4's Avatar
i was thinking about quad-turbo... sounds like a better idea
