i am so scared...
Old Dec 21, 2007 | 08:37 PM
auditurbo381's Avatar
Default RE: i am so scared...
i a pretty mechanically inclined. if i take it apart i usually can put i back together. i am a little hesitant due to how tempromental these cars are. what are your sugegstions. and i am REALLYYYY tight on money. especially right now during the holidays
Old Dec 22, 2007 | 12:05 AM
so would coolant in my oil cause my sounds like a subaru problem?
Old Dec 22, 2007 | 01:28 AM
a4whisperer's Avatar
You may simply have too much oil circulating causing it to bubble. Drain a half quart and go down about 1/4 a quart from there if you can and see if the problem has been resolved.
Old Dec 22, 2007 | 02:08 AM
would the bubbles be from too much oil if the disptick is reading right??
Old Dec 22, 2007 | 07:22 PM
acetrebo's Avatar
you could also get coolant into oil from the oil cooler leaking, which is located underneath your oil filter.
I do not know if your model has this or not, its a common failure point on the B5.
this is much easier to repair than the head gasket, if its the cause of the problem.
otherwise sounds like a head gasket. Any noticeable engine problems or decrease in performance?
Old Dec 22, 2007 | 09:07 PM
my car sounds like a subaru. just happened on my way home. lol thats my decrease in performance. but otherwise no. no warning of this at all
Old Dec 23, 2007 | 12:04 AM
nordska's Avatar
when you say sounds like a subi, do you mean that noisy tick/click type sound when accelerating? valve noise??
Edison528
B7 Models
13
Jul 27, 2011 12:34 AM
fcamargo6thave
Dec 29, 2007 04:48 AM
fumoazul99
Jul 14, 2007 10:25 AM
Fall0ut
Dec 21, 2006 02:46 AM
duffman
Aug 11, 2006 05:52 PM
