I fixed my airbag light!
I had the airbag light come on after I did some work on the radio. I had installed an inline FM modulator with a signal amplifier for my XM Commander receiver. Whenever I tried to clear the code for the airbag (driver side high resistance), it would come back on immediately. I was about to take the car in to the dealer.
Well, I had the vag-com hooked up to check for an intermitten evap leak that was throwing a code. I had replaced the vacuum check valve next to the airbox and was hoping that would fix it. While hooked up, I checked my radio faults and noticed some weird code about controller internal memory error (I wish I had saved the code to know for sure).
I cleared the codes (I also had some antenna error due to using an in-line FM modulator with my XM receiver). Then I went to the airbag controller and cleared the code (driver side high resistance-01217) and it stayed off.
For everyone who has had this problem, check and clear your radio codes and see if that doesn't fix the problem.
ORIGINAL: Redgoat
hmm i take it you have stock deck?
I shut the car off and started it several times and checked for airbag faults each time. No fault! I'll be sure to post if the light comes back on.
yeah mine is on too. i bought the car with a pioneer installed and it has xm capabilities. not sure of anything else.
but my stupid airbag light is on too. i dont know where to start with getting it to turn off.
ORIGINAL: toyolla86
